***PRICE DROP***Yuneec Tornado 920+ Complete System as new with extras....
London, ON Canada
Nearly New Yuneec Tornado H920Plus System
Purchased new 27 December 2018 (with 6 month warranty) from Vertigo Drones
Only 3 flights
Reason for selling: change of business direction
All items in factory kit are included and are in as new condition
Tornado H920+ (Plus) Case
1 - Tornado H920+ (Plus)
1 - ST16 Ground Station
1 - Yuneec A10 AC/DC Dual Multi chemistry Balance Charger
1 - AC Power Cable
2 - Balance Plugs
2 - Charging Cables
1 - DC Power Cable
1 - Smart Voltage Checker
16 - Motor Screws with Spring Washers
8 - Quick Disconnect Screws
1 - 2mm Allen Wrench
1 - 2mm Hex Screwdriver
1 - USB to Micro USB Cable
1 - Quick Start Guide
1 - H920+ LED Status Indication Guide
1 - ST16 Neckstrap
4 - A Carbon Fibre Blades
4 - B Carbon Fibre Blades
3 - 4000mAh 6s LiPo Batteries
1 - Carrying Case for the H920+
ProAction with CGO4 Camera Case
1 - CGO4 Camera
1 - ProAction Ground Handle
1 - ProAction Cell Phone Holder
4 - CGO4 Rubber Dampers with Retaining Pins
1 - CGO4 Cleaning Cloth
1 - 2600mAh 4S/14.4V 0.3C 37.44 ProAction Battery
1 - Charging Cable for the ProAction Battery
1 - Balance plug for the ProAction Battery
1 - ProAction Quick Start Guide
1 - Carrying Case for the CGO4 Camera
All EXTRAS BELOW INCLUDED - NO CHARGE
2 - New GensAce 6s 5000mAh batteries (2 charges) Value $217
1 - 128gb Sandisk Extreme Pro U3 card -Value $40
1 - Yuneec Camera adapter for CGO3+/CGO-ET - Value $147
1 - Neewer Camera ND filter kit - Value $20
1 - Mushroom antenna - Value $9
Asking price $2250 ***NOW $2150*** plus shipping to US lower 48 & Canada
Video of it in flight is available if requested....
Here is a quick cobbled together video - CGO4 settings were just default as it was a test of the flight only - 2 separate locations on 2 dates - - both days was quite windy at about 20-25kph.
Hi I'm curious on the 2 aftermarket batteries you have can you give me a detailed spec on those bat's like 5000mah 6s so on. Reason I ask is I have a h920 and Im Looking for replacement bats thanks for any info and Ill spread the word on the sale of your bird if it's still available thanks again
The 2 Gens Ace batteries are 5000mah 6s LiPo 45C rated. The 2 are the same height and width of the 3 Yuneec batteries, and are a bit shorter. They fit into the stock battery compartment with only a slight modification to the lower lip of the box to allow more space for the cables. For retrofit you need to change the EC5 plugs to EC3 to plug into the 920. Here is a link to a conversation about replacement batteries for the 920/920+
Link to the vendor:
It's a very nice setup Dan, I just purchased pretty much the same setup and I don't know how I would part with it lol good luck and if you do sell it someone will enjoy it.
fabricolaundry
