problem powering up the typhoon
I can't power up the H!
if I release the power button the H totally shuts down.
Does anyone have an idea what the problem can be?
You can find a video here: MEGA
the key to open the file is: !A1o5W25IF-65Cu9Ymz63GyEk8jP6sTP8tIiEX2mnQIA
Thanks for your help.
Bart
Bart
It appears something is wrong with the power button. In your video it looks like it's depressed more than it should be. If you release the button immediately after you hear the rising tone it should stay powered on.
that is because the top half of the boddy is not nicely closed.
I have opened it to replace the button but that is not the problem.
Okay. That explains the appearance. I presume if it's not the button, the main board is bad. If you just recently purchased this H you should return it for a replacement.
I believe you are I'm no fly zone, get the nfz s/w from yuneec
Bart
It looks like you might be in an no fly zone. The typhoon will not start until you get the yuneec bypass software or move away f r I'm the zone
dharminder
