Prop threads size help please.
Hi all.
Okay so I had a minor crash into the side of my car. Basically the props smacked the side of the car until it hit the ground and flipped.
Everything seems to be fine even the props are in good shape. My problem seems to be that one of my motors screws (the part you screw the prop on in case that is not the right term) has some damage. I had a hard time getting the prop of and it seems difficult to get back on. It looks like I could use a tap and die set and clean it up as the damage does not look terrible just enough to make putting props on properly hard. I don't want to get them cross threaded.
This is a B motor so I was wondering about the thread size so I could use the proper die to clean the motor screw and die to clean the prop that was on.
zuhoouk
