Q500 4K and CGO3+ Camera
Bought a camera off ebay add said CGO3 camera
When i received it it was a. CGO3+
Question is can it be modified to work on the Q500 4 k
Not well at all. It's not just that it is too tall. It also has a couple pieces that have to be trimmed off to let it slide onto the mount (or trim the drone part). The main issue is that the CG03+ will not have the tilt function when mounted on a Q500. The tilt will work when mounted on the Steadygrip, but not on the Drone.
Thanks for the info
It won't work well as said above.
The bottom line is that you have bought an item off ebay that has been misrepresented so you are entitled to a resolution. Contact the seller and if he/she won't rectify then go through ebay channels for resolution.
paulrs
