q500 battery charger problem
I tried charging my p3 today and the red light flashed as usual and tried balancing with the green flash. The problem is it never stopped doing that sequence. I tried a different battery and the same thing. Another the same so I tried a different charger and the same. How could this happen when I know all 3 batteries are good.
tha is normal balancing light flashes not once or twice ,charger repeat sequence untill perfectly balanced the voltage then charge the battery with blinking red
That's what I thought also but it's 2 red flashes and one green etc. continuously which is different than ever before. It never seems to balance.
I am checking the remedy.
Peter,
What is the"p3" you mentioned?
I
Peter,
I'm sorry, the power 3 for the q. I never had to take so long to get the balancing take so long and not start the solid green. The batteries are all good so I did something wrong or I will wait longer. I found where someone said it takes an hour at times but I never experienced that. hm. once again.
I also just realized after just taking a straight up lift there was enough power and voltage was over 11. xxx. and immediately went down so I am going to empty one until the warning comes on and try later. Make any sense?
I tried a 3rd battery charger and all is well.. The other 2 are not. Kav sent me 4 chargers and said they didn't and that yuneec did which was bs because the return address was theirs. I guess because I went there 3 times they needed to unload them. Just to make sure I tried the previous 2 and still bad. I guess some of those were faulty. weird but it didn't cost anything. Hope you made it through the storms.
katerosefinejewelry
