Q500 Warning !
Steve Carr
Missed Approach
Staff member
Premium Pilot
Bessemer, MI
Always place a sd card in your ST10 under the battery. That is the only way the telemetry data will be recorded. You must have this card installed for warranty service.
You can use any card up to 16GB. Format it using FAT32.
Reactions: TheChiefUSN
I have looked at the data on the card is there an easy way to read it if i lose the Q?
It's a comma delimited file, .csv which can be opened with Office or Open Office. There are two columns labeled Latitude and Longitude. The last entry in those columns are the final signal received from the Q500. You can copy and past those numbers into Google Maps to find the location.
Give it a try and see if it works for you.
Frida Gold
