Quick Release Propeller Installation
Can anyone take a pic of both sides of the quick release propeller for the Tornado H920+ ? They should be easy to install, but for some reason I am having difficulty. TIA
They are easy to install. Is it possible that you have mixed them up? Maybe you are using the wrong propeller or the wrong mounting plate. You cannot mix A and B mounts since they mount in the opposite direction. It is a very common mistake.
My H920+ did not have the quick release hardware installed. I bought some and am having difficulty installing the pieces to the motors and props. I think some photos might help.
Are you sure it is a H920+ not a H920? The plus is usually delivered with quick release already mounted. Unfortunately I cannot supply any photos.
Nevertheless they should fit just fine. Motors and propellers are the same on both versions.
These photos might help. Torque to 6-8 in.lbs. Recommend using Loctite 222 Threadlocker and balancing the props. Do you have the ST16 controller? If you have the ST24 you probably have a H920 not the plus. 83F81A7D-10B0-48F4-9F81-5C3406BBA919.jpeg9446C78B-7E8E-427A-B0C9-85A3CE3E40E6.jpegED2D4FFE-7A30-43B7-BBBF-BAAE480C6DB6.jpeg
vbd777
