Rear LED
Hi since getting my typhoon h when flying the rear led flashes green/white every couple off seconds when i put it into angle mode it flashes purple/white
Has anyone came across this problem before
Thanks
Then in smart mode its green/white flashes so i take it that this is ok as well
As you can find it in your manual
- The Aircraft is in Smart Mode with GPS lock
Glows solid green
- The Aircraft is in Angle Mode with GPS lock
Glows solid purple
NOTICE: White blink between solid flight mode indicates enough
satellites for Watch Me/Follow Me.
Reactions: Timothy Reece
Thanks
That sir is not a problem what it means is you've got more than eight satellites posted and you have an excellent GPS what if you have less than 8 satellite it will only flash purple or green
Smyers
