Sd card connection
Camera can't find sd card
In general, there are two main issues (and a possibility) when this occurs:
Bad SD card. (I use fat32 on CGo3 cards, many other folks use different formats)
Bad Wifi board. (Card reader failure is fairly common)
Far less often, a camera firmware or update glitch.
Have you tried different cards?
Anything related happen between last time it worked and first time it did not work?
Was this the Q500 in the farmer's field for a couple months?
Lol no farmer field. This is the one we replaced the wifi board. After that repair it was working fine and has been setting on the shelf I'm going to try formatting the card again the see if an update works I have image and wifi connection
Reactions: WTFDproject
Alvaro
