Ok, I'll bite. Have you heard of Carolina Dronz? Yuneec ST24 Smart Transmitter Replacement Lithium Batteryanyone know where in the usa can get one
Edit: This battery is good for the ST16 as well
Oof, I stand corrected. I could have sworn I read somewhere (here or on RCG) that this battery would work. Sorry for the confusion.This are two different batteries YP-2 and YP-3A
£43, your having a laugh its only li-ion not li-po.
Wrong connector for the ST-16. The battery in my ST-16 is the YP-3AOk, I'll bite. Have you heard of Carolina Dronz? Yuneec ST24 Smart Transmitter Replacement Lithium Battery
Electrically it is the same battery as the ST-16. Different connector and the wire gauge is smaller than the ST-16.Oof, I stand corrected. I could have sworn I read somewhere (here or on RCG) that this battery would work. Sorry for the confusion.
??? Post is almost a year old. Sort of a dead thread. Why respond?Wrong connector for the ST-16. The battery in my ST-16 is the YP-3A
An cheap alternitive to buying a second battery is simply to get an external battery bank. You can attach it with some velcro to the underside of the ST-16 and connect it with s short usb cable. This would also eliminate the need to open up the transmitter and change the battery. That is probably some extra wear the connecter wasn't designed for on a constant basis.Does anyone know where I can buy a spare ST16 battery?
UK based.
Cheers
Same as I do, a powerbank with 8000 mAh capacity and a little bit of velcro is all I need to fly all day long. This also have a solarcharger to maximise the battery.An cheap alternitive to buying a second battery is simply to get an external battery bank. You can attach it with some velcro to the underside of the ST-16 and connect it with s short usb cable. This would also eliminate the need to open up the transmitter and change the battery. That is probably some extra wear the connecter wasn't designed for on a constant basis.
