ST16 Keeps crashing
Hi there
The ST16 keeps crashing, often mid flight. I was told this might be due to the memory on the ST16 being stretched due to there being too much map data on the device. Is there a way I can prevent the thing saving map tiles and does any one know how to clear the memory?
When you connect the ST16 to your computer and click on the icon for the controller you should see the amount on internal storage available.
Hi there
There are a few things that "may" cause this. If the battery is not that good any longer, and if the fans are not working correctly it may be overheating.
Thanks for relies everyone, haven't had time to try them yet. The *** thing is brand new.
I was told map storage is probably the problem from Yuneec UK. To be honest I am mightily unimpressed with my H520, the only thing going for it so far is it's ability to operate in the wind, other than that it is far inferior to the phantom 4 pro.
nvjfirut
