ST16 Not Powering Down Completely and Flattening The Battery
Hi Andrew, have you pulled the St16 apart and cleaned the area with electrical contact cleaner, while you are in there give the pots a spray also and most of the switches and sliders. After that has dried before you close up hook up the charge cable and battery and see if the problem still exists. Do a bit of wriggling etc and observe if the problem starts and stops. Also don't forget the on off switch as I have had some of these that need a good clean or replacing. Johnno Hennessy.
Reactions: Andrew Grant
Hi Mrgs1,
Onew day I hope to be able to post links like that, but computers and I don't send each other CHRISTMAS CARDS. I am getting there and enjoying it. Johnno Hennessy.
I agree. On the very rare occasion that I've had dealings with Yuneec UK I have found them to be very good at responding. Last time I rang them up they answered within just a couple of rings...I was gobsmacked! However, I believe the OP is located in the U.S.A where I gather that the story is starkly different.
I'm in Australia - fortunately or unfortunately haha
dubiousflyer
