St16 wifi module
The wifi module in my st16 has failed, won't turn on and it will show me any wifi networks to connect to.
I'm looking to buy one from someone whose st16 isn't working. Get in touch with me if you do and know how. I have not tried yet, but the moduled usually are removable.
UPDATE... I was correct about the wifi module failing. It took only 2 days for delivery from yuneecskins.com and 20 minutes to put it in. I'm up and running. Thanks for the help Doom.
The module is replaceable. Contact @Yuneec Skins for price and availability.
The usual cause of failure is the controller being turned on without the WiFi antenna being attached. Have you opened the controller to check to see if the module is plugged in and the antenna leads are attached?
dubiousflyer
