ST16S for H520 on Typhoon H Plus ?
Hi to all
I have this spare completely new ST16S controller (YUNST16SEU), never used.....for H520 drone.
As Typhoon H plus should be using the same controller , is it possible to use this one on Typhoon H plus too , or software is different ?
Any way to change the software if necessary '
Hi to all
Typhoon H Plus, H3 and the original H520 use the same controller. The software is different for each one. The software can be changed.
This is the guidance to convert an ST16S from H520 to HPlus, and includes a link to the required firmware.
  • ST16S for H520 Conversion to ST16S for HPlus.pdf
Reactions: Frontier and dxer
You wrote that for each drone firmware is different. In this PDF there is onyl link to download H Plus firmware, do you have one for H3 as well and is this the same for EU and US ?
Check out this document Way To Fix Drones project where you will find the instructions and links.
Reactions: Pier2162
Ludwig
