Start/Stop, Red cap is broken
My Start/Stop Red cap popped off, is there a way I can get a replacement or use the aux cap?
The easiest fix is to use the cap from the Aux button.
Gently grip with needle nose pliers and they will pull off.
The switches will work without the caps also.
Reactions: WTFDproject
I doubt the red button is included in the link below. You can contact John Mitchell @Yuneec Skins. He may have some that he could ship in the same order.
Personal preference: If you are going to spend $18 on a button, consider buying another remote and/or getting one that doesn't work that you can use for spare parts.
One plus is that Yuneec Skins seems extraordinarily reliable, so your quality will be very good on anything you get from him.
Question: How did you break the button?
Reactions: 7cyclops
I have no clue, I started using it again and it was like that.
PerfectPlanqa
