If you read my subscription on YouTube....
But here it is.
So I purchased a cheap, in excellent condition, second hand Yuneec Steady Grip from eBay.
I wanted to attach my Typhoon H CGO3+ Camera to it. I tried with 8 AA batteries and after 15 minutes they were flat, but it had at least worked. So I decided to do the LiPo upgrade with a couple of extras.
First thing you need is the Steady Grip.
1. It must have a slide on connector with three pins. (Not just the 3 pin plug)
2. It needs to be the 8 AA battery version, not the 6 AA.
I purchased this battery, it fits perfectly.
Turnigy nano-tech 2500mAh 3S1P 5~10C Transmitter Lipo Pack (Futaba 6EX and 3PKS) (AU Warehouse)
This is the LiPo battery voltage tester and low voltage alarm I used.
Turnigy Lipo Battery Voltage Tester 2-8S and Low Voltage Buzzer Alarm
I also used the XT60Plus plugs.
New XT60plus with Insulating End Cap (5set/bag)
But I have decided to swap these to the EC2 connectors as they are a little smaller and the same as inside the ST16 controller and I already have a charge lead with that type of connector on my LiPo charger.
EC2 Female & Male (5pcs/bag)
One of these 3S JST-XH balance extensions.
JST-XH 3S Wire Extension 20cm (10pcs/bag)
Lastly this great little double pole toggle switch, from Jaycar.
DPDT Flattened Actuator Mini Toggle Switch | Jaycar Electronics
I plan on adding this 2.5A USB adapter when it arrives.
Turnigy USB Power Adapter
If you have any further questions or comments please leave a message below and I will get back to you.
Thanks for watching.
