Switch gimbals model setup
Hi! I just got a cgo-et gimbal and have successfully tested it. But I have a problem setting up the st16 in a good way so I can easily switch between my original cgo3 gimbal and the cgo-et.
I would like to have two models programmed, and depending on which gimbal I currently have mounted, I want to select the correct model.
But the problem for me is that I can not bind the same typhoon drone to two different models, can this be done? It does not show up in the bind view at all, independent if I put the drone in bind mode or not by tilting it.
Now I always have to rebind the gimbal again and change camera type for current model, feels a bit strange this is the way I must do it.
Does any of you know, is there a way to make two models, same drone but for two different gimbals? Thanks!
/Sebastian
gocdunn
