Yes, try it out well ! Camera and all, I am hoping you received a great unit and fly safe !Till now it's doing just fine. Have updated everything with the standart firmware pre first flight and i have very good stability on everything, so many Satelites at any time and the range is more than satisfying with stock antennas. I think i made a good decision but to be sure i need a few more flights.
Keep in mind the unstable clock on the st16Tom, what is your goal here? An interesting post, but over my head. I don't think telemetry is normally used except as a troubleshooting aid when there are problems or a crash. A lot of us have problems with the time settings not reflecting Daylight Savings Time. Do you mean that when you fly 5 times, you then have trouble locating telemetrics for flight # 2 or whichever?
No I'm not referring to 5 separate flights but instead referring to 1 flight at a time. Then if I'm wanting to use the video and telemetry to make a telemetry overlayed video with DashWare apps I am having difficulty aligning the data with video because for example if I have a 14-minute video recording I then look at what is supposed to be the telemetry file data for that flight I usually find the data ranging over 2 separate files and in all adding up to about 4-5 minutes more data time than what i have in video files. So correct me if I'm wrong but I thought the Telemetry data doesn't start until you actually take-off from the ground so if Im starting my recording before i take-off and not stopping the recording until after I land & shut off the propellers shouldn't the telemetry files line up relatively close to the video recording? Im just curious to how to set the time properly on the H itself cuz I have the ST16 date and time synced perfectly on every flight without having to reset or resync each time.Tom, what is your goal here? An interesting post, but over my head. I don't think telemetry is normally used except as a troubleshooting aid when there are problems or a crash. A lot of us have problems with the time settings not reflecting Daylight Savings Time. Do you mean that when you fly 5 times, you then have trouble locating telemetrics for flight # 2 or whichever?
