- Joined
- Sep 8, 2016
- Messages
- 8
- Reaction score
- 0
- Age
- 88
Why are data intervals not consistent? What determines data intervals? Can the intervals be set externally?
I did finish fifth grade. My question in no way asked why files are of different lengths. The definition of interval is the time or space between two events or objects. In this case, the "data intervals" are the times between data points within a file. Examining my telemetry files, I find as few as eight and as many as 23 data points recorded per second, the mean is around ten. Hence, the question of why. Answering what might explain the why. The inconsistency between intervals might be corrected if the intervals are settable. Another advantage of the operator being able to set the intervals would be to significantly reduce the file size. Currently, for my purposes, I see no real value to 9,000+ data points for a 15 minute flight.On/off cycles. Short flights=short telemetry files, long flights=longer telemetry files.
I get it.... The bottom line is you have no answers to my questions.
