- Joined
- Jan 21, 2019
- Messages
- 1,096
- Reaction score
- 660
I just thought that I would put my thoughts together, and write about "The Drone Game" an addendum to A Droner's Guide to Surviving Virginity (since mother nature disrupts my intentions of going to work this morning)
There is probably more new operator out there anxiously looking for guidance, tips, and hints to help them enjoy this amazing hobby safely than ever before, may it be someone, who is starting out as a hobbyist, with the intention to grow as a commercial operator. I am extremely surprised by the mockery in the comments of some of the members, as well as the rhetoric's being shared that is out of topic. More experienced RC “pros” are none sympathetic to noob mistakes, and call them out for their lack of understanding and skill level. Instead of being boastful, I feel that we should help newbies to gain enough confidence and experience to fly safe enough to enjoy the hobby and learn how to fly a drone. After all, it is in our interest also because that way they pause less risk to the hobby getting banned entirely and if they are happy drone pilots, they will inspire others to fly as well.
First off let us start, with the FAA rule and regulations, so we do not beat the VLOS, BLOS and the proper use of a VO. I will cut to the chase, visit this site. FAADroneZone and work your way backwards in learning about the Drone regulations here in the U.S. And if you reside outside of the U.S, research on the rule and regulations in your country.
Before we get dirty, I would like to share two things.
As you start learning about drones, you might find yourself lost among unfamiliar terms. If that’s the case, you’re not alone. Drones themselves go by many names, from UAV to RPA, and even the drone industry is still struggling to reach a consensus about which name it likes best. But every new hobby comes with a list of specialized terms, and learning these words is part of the excitement of immersing yourself in a new world. Quick Reference Guide of Drone Terminology
The controls.
Throttle: Makes the quad ascend (climb) or descend (come down).
Yaw: Rotates the quadcopter clockwise or counter-clockwise.
Roll: Tilts the quadcopter left or right.
Pitch: Tilts the quadcopter forward or backward. These controls are also referred to aileron (roll), elevator (pitch) and rudder (yaw)
Flight modes. There are many different flight modes, as far as Yuneec Products, there are:
In it best to familiarize early, because flight modes or other calls intelligent flight modes is what makes flying a drone fun.
This is why, when you first receive your drone and has gone through the basic fundamentals, and ready to fire it up for the first time......... HOVERING is very important! When I have a new drone, I will fly that drone on a hover for a week, this may sound boring, but this stage is very critical, because you are getting familiarized with the control inputs, customizing the RC curves, sensitivity, rate (if your RC allows you customize) It will seem pretty tedious for first-timers as it requires concentration, but practicing this will help improve your flying skills, specially if you are flying in none GPS mode.
Hovering: This is where you maintain the drone’s position in the air. More advanced drones’ come with an altitude hold, which allows the drone to hover without the pilot controlling the throttle. Cheaper drones will require the pilot to maintain its altitude by using the throttle.
After the hover (while in none GPS mode, if you wish.) fly in large orbit circuit, while facing at the drone at all times, and then tighten the circuit to where the drone flies safely closer to you, once you master this practice the drone noise-in, in figure 8.
Orbit: When you circle an object on the ground. Often used when shooting aerial video to deliver cinematic looking shots.
Figure of 8: When you fly your drone in a path resembling the figure 8.
Most common Drone problems.
Signal Issues
You are probably flying outside the manufacturer's latitude specifications.
On a location with heavy WiFi traffic (Turn off WiFi and Bluetooth in your RC settings)
Problems Taking Off
Are you in the NFZ zone? Did you wait to acquire a satellite signal?
For NFZ removal, contact Yuneec.
Poor Battery Life
Poor battery life is something that is very common. Give is some juice before you fly.
Wrong Flight Direction
What happens if you steer your drone to the left and it goes to the right? Are you in RC mode 1 or RC Mode 2?
Miscellaneous.
How to retrieve telemetry: How To Get H Plus Telemetry Files
Advance IMU and Gyro Calibration: Locked out from IMU and Gyro calibration?
**** If I miss anything, kindly contribute below.
- Fly Nifty.
- If I can do it all over again.
- At the launch pad.
The controls.
- Read the manual, specially make a footnote on proper binding to RC-AC. RC -Gimbal.
- How to update a build/software.
- How to downgrade a build/software.
- How to calibrate. IMU, GYRO, RC Mapping, and Compass.
- And ask yourself a question of why we need to calibrate, how often, and the importance of these tools.
- Angle.
- Sport.
- POI
- Journey.
- Curve Cable Cam.
- Team Mode.
- From hover to flight.
Signal Issues
Problems Taking Off
Poor Battery Life
Miscellaneous.
