Has anyone had problems with the throttle not responding? I'm sure it's a problem with the joystick on the st16. In hardware monitoring mode it will sometimes got to max and other times it only goes to about 70 percent. Seems like a bad connection. This happens in rabbit mode. When in turtle mode is won't even climb with the stick held full up. This is intermittent.
