Tip Over
Glendale, CA
Hello everyone haven't been on here in a while nor have I flew in sometime.
Anyhow, I was flying yesterday and tried that hovering about 2 feet off the ground to do the on/off switch tap to land my H Pro w/ realsense and it was working then as it touched down it tilts backwards and scrapes but not breaks 2 props which i threw away to be safe.
Now I change batteries do all the calibrations other than compass since I had purple/white led's on the flight before...all goes well im up about 10 feet and my H slightly slowly drifts to the left...its slight so i continue to fly up and still purple white and at 300ish feet up and 2 blocks down video feed freezes...kind of cloudy so i lost LOS and control.
Thank God RTH worked and MANUALLY landed no problem...im confused as to what went wrong and can a non violent nothing broken cause my second flight issues? i mean nothing broke cracked etc even the rotors didnt break....just that beep indicating 5 rotor mode error land now warning.
Your thoughts and ideas are appreciated
AdvaikTasteofPurity
