My landing gear would not retract after the firmware update. Only one leg would move about 1/2 inch. The other would not move at all. After putting a little pressure on the legs I got it to function again. Never had that happen before.
Then what are they talking about in the manual ?:
ACCELEROMETER CALIBRATION
STEP 1) Place the TYPHOON H on a level and stable surface. Switch on
the ST16 Ground Station and the aircraft and wait till the RC and WiFi
connected.
STEP 2) Make sure the FLIGHT MODE switch is in the middle position.
Tap the GPS Calibration button, switch off GPS and choose 'ACCELEROMETER'.
STPE 3) When the main LED indicator blinks red , green and blue
slowly, hold the motor start/stop button to start the motor, then the
main LED indicator will blink red, green and blue rapidly. Push the
throttle joystick gently above the middle position to take off the
aircraft. Meanwhile, keep the aircraft hovering manually until the main
LED indica tor blink s r ed, gr een and blue slowly again.
STEP 4) Landing the aircraft and hold the motor start/stop button to
stop the motors, the copter will restart automatically. You will recognize
the this when you he ar the r aising tone.
Where you got these step??????Then what are they talking about in the manual ?:
connected.
connected.
In what manual ?
The last manual release is not 1.1 ?
In the same ZIP package French , Italian and Spanihs languages manual is in version 1.0, but english is 1.3.
They should be really carefull with this because if we do something wrong per manual instructions, then they will be the one paying for this.
Whenever new firmware is released with new features, there should be manual for this features. I don't see anywhere official instructions on this new features.
That issue can often be taken care of by rebinding.My landing gear would not retract after the firmware update. Only one leg would move about 1/2 inch. The other would not move at all. After putting a little pressure on the legs I got it to function again. Never had that happen before.
