Typhoon H connectivity issue
Hi everyone. I have a strange issue that occurred recently. I have connectivity from the cgo03+ camera to the st16 but all radio connectivity is down including st16 showing voltage and GPS or any data from the craft. And the controls don't work. I have perfect camera connectivity. What can this issue be? I connected the typhoon to a pc and there I can see the info. What is wrong. Please help
It sounds like the aircraft is not bound to the controller.
Tilt the aircraft forward by 45 degrees or more and return to level at least two times, until the Main LED flashes orange. Then go to System Settings, Bind, Refresh, select the SR24xxxxxx in the left column, then select Bind button on lower right.
Go to the 1:15 mark in this video.
dharminder
