Typhoon h does not want to fly
Go into your channel settings, and check that the throttle stick is giving input.
I see you have a good GPS lock,
You are in Angle mode.
Unless you are in a NO FLY zone, no reason why it will not throttle up.
If you're in a no fly zone (5 miles with in ATC) the motors on your drone will not even start, all you will get is a beep!
Re-calibrate your controls and see if that works. Or and maybe you need to clean the control stick.
Hi 1.5 months I have a problem with my dron
The engines start firing but the dron does not react to the gas and does not fly up
He has been on the site 4 times and they are constantly exchanging something but the problem returns
Did anyone have a similar problem?
Have you checked the Hardware Monitor while you move the throttle stick? It should show movement at 100 percent if it works correctly.
I'm not sure you are calibrating the sticks correctly for full function. Unless I'm wrong, I start at the top left and move it along the edges all the way around. On the ST16 go to Systems settings, then tap ok, then tap on Hardware Monitor. Here you can see if stick (control) is moving correctly.
in Calibration J1 not worked , in hardware monitor throtlle worked i dont understund this :(
think st16 faulty, in chanell setting he worked to but today 100% max yestardy only 60%
im send the copter and today got @ from yuneec i dont understund :
Dear
unfortunately there were no flightlogs in the ST16. The System Folder is
completely empty/ deleted. An examination of the warranty claim can not be
carried out.
Please send us the Files from the ST16 if available. In case the files are
not available anymore, please find attached our cost estimate no. 10003249
for a complete technical checkup and a Reset of the system.
If you would like to accept the offer, please inform us by e-mail
([email protected]) and give us the service number for reference.
This offer will last 14 days.
Mit freundlichen Grüßen / Best Regards
Dear
carried out.
Are you saying that, as far as you were aware, the flightlogs were in the system folder and you didn't delete them?
If you did delete them, then Yuneec won't be able to determine the fault through those nonexistent logs and you won't get it fixed under warranty. Yuneec won't honor a warranty without seeing those logs.
bluie707bayboy
