PatR
Premium Pilot
There is a repair center in Burnaby, here is the site. Drone Repair
Might want to call them first. The site states they handle DJI, Freefly, and FLIR.
The funny thing is, my drone only came with a quick start manual and nothing else. I had to download the full manual.
I think I am getting the hang of it though. I use it in angle mode only.
Yes, I think I need to upgrade the YouTube membership.Wow the YouTube compression is terrible on that video. Not sure what's going on there, but you do look like you're doing alright.
Hey jethro in Aus I only ever fly in angle mode I have 4 yuneec uav,s and have never had an issue with any of them, I also put it down to that I have never done an update on any of them, hope u get it sorted out cheers peterGood morning all. Hope everyone had a great Xmas!!
Mine has turned out to be a little bitter sweet. Started off great. Opened up my new Typhoon H drone on Christmas eve. Super excited. I am new to the drone world. Read through all the documentation that night. Made sure batteries were all fully charged and took it out the next day to test it out.
Took it up to the park with nobody around. Was a clear cool day. Few degrees above freezing. Started everything up. Followed directions in the instruction manual. Booted up the ground station first. Once it was up and running, powered on the drone. Everything seemed to connect as expected. Powered up the rotors. Again, wasn't planning on doing anything too exciting for first flight. Just wanted to see it up in the air and do a few manoeuvers.
As mentioned earlier, I new to the drone world. According to the user manual, Yuneec indicates new pilots may find it easier to start in 'smart' mode, but should switch and learn to fly in 'angle' mode as soon as possible. As such I started off in 'smart' mode.
I lifted off to maybe 8 feet in the air and hovered for a few seconds. I wanted to then try some basic manoeuverability (ie: left and right). The drone responded correctly to moving right, but did not respond correctly when trying to bring it back to the left. Instead it seemed to continue moving to the right. The drone was starting to drift. Which is when I seemed to make my fatal mistake.
Again, according to the manual, Yuneec says that the drone can be put into 'Home' mode and it will fly back to the pilot and land. Well that is what I tried. I flicked the switch to 'Home' mode. Did not touch any of the other controls. The drone promptly flew off to the left and crashed about 60 yards away in an open field. My inaugural flight lasted less than a minute. I didn't see the actual impact as there were some bushes that obscured my view.
Unfortunately, the drone came down pretty hard in the field. When it decided to fly away after being put in 'Home' mode, it took off pretty quick. Broke 5 of the 6 propellers, 3 of the six rotor arms and the right side landing gear. The camera was knocked off in the impact as well. Not sure if it has sustained damage?? It is off center stabilized (ie: it's not level). Not sure if it just needs to be recalibrated or not?? But it took a pretty good hit.
So I now have a very expensive broken drone. Now that I've finished crying : ) I have a couple questions I'm hoping people can weigh in on.
1) Although I am very much a newbie to the drone world, I am fairly tech-savvie. I don't believe I did anything wrong here. According to the Yuneec instruction guide, putting the drone in 'Home' mode should have made the drone fly back and land. Is it possible this was some kind of software or mechanical defect?? Do I have any options pursuing this with Yuneec?? I'm anticipating a fairly expensive and lengthy repair process. Which takes me to question #2.
2) What are my options for repair?? I believe I can send the drone in for repair directly to Yuneec. Suspect that may take awhile though as I would have to ship it back to them. Think they are in California. I am in Vancouver, British Columbia.
I suspect I could also order the parts and try to make the repairs myself. But I'm not sure I'm completely comfortable making the repairs?? If there is something actually defective mechanically with the drone, I wouldn't want to make the repairs only to have it fly away and crash on me again. Can send photos of the damage.
Can I get the repairs done by a third party (ie: does Yuneec have authorized repair shops anywhere else in the country, or better yet Canada)??
Thanks in advance for any feedback anyone can provide!!
Thanks Eagle Eye : ) Even with the exchange, that works out cheaper than what Staples is trying to charge me. Think I've seen a few how-to videos on You-tube showing how to replace the arm. Doesn't 'seem' all that difficult. Especially if the motors are already pre-installed in the arm tube. The one reason I didn't go that route in the first place was I was hoping Yuneec would warranty the repair right off the bat.If you are willing to attempt replacing those parts yourself, your total cost of the
parts themselves is about $200.00 (not including the props):
Yuneec Typhoon H Folding Arm Assembly A
Yuneec Typhoon H Folding Arm Assembly B
Yuneec Typhoon H Landing Gear Struts
Mount Set: Yuneec Typhoon H CGO3+
Happy Sunday everyone. Finally able to post a bit of a follow-up here for my repair.
Has been a while. Almost three months now since I started the repair process. My experience with Yuneec customer service so far has not been very fun. In fact I have to admit it has been one of the most frustrating things I have ever gone through.
This has definitely been an adventure ... and not of the good kind. Being a Canadian resident, Yuneec uses Staples (the office supply store) as their authorized Canadian repair center. Dealing with Staples as the repair shop has proven to be somewhat challenging. This actually seems to have caused most of the three month delay as there does not seem to be a lot of coordination between Staples and Yuneec. But that's a post for another day (if any other Canadians owners are interested in the process up here : )
After numerous delays and an eventual follow-up with the Yuneec customer service supervisor, I have been informed that Yuneec considers my crash to be user-error and they will NOT warranty the repair cost.
Have a few questions I'm hoping people here might be able to advise on:
1) Yuneec has reviewed my flight telemetry from the crash. What they are saying however does not jive with my recollection of the events.
Yuneec is saying the telemetry shows I started off in Smart mode, then switched to RTH mode and then switched back to Smart mode. The crash was caused by the unit being switched back into Smart mode within the safe circle. I don't believe this was the case though. Although everything went to **** in a matter of seconds, I do not believe I switched back to Smart mode. I even documented all the steps I (believed) took place back in December (so not totally going by memory from 3 months ago).
I did start off in Smart mode (as the operation manual indicates 'new pilots may find starting out in Smart mode to be easier to learn how to fly'). And I did switch to RTH mode when I sort of panicked and thought I was starting to lose control of the bird. I do NOT recall switching back into Smart mode from RTH. From my recollection (again, everything happened so quickly), it was switching to RTH that immediately caused the bird to take off like a bat out of **** and crash. I didn't have time to do anything else but watch helplessly as my $1000 investment hit the ground about 60 yards away probably doing 30MPH.
So my questions for this are:
- Can the telemetry be wrong?? I don't have the ST16 receiver at the moment to pull the flight logs from, but I did have the Staples repair technician (Paul) pull them and send them to me. I'm not exactly sure how to read the files though?? I will attach the file I believe is in question (telemetry file #6) with this post. Will rename the file to .txt (as I don't believe .csv is accepted on this form). Would someone be able to review and advise if Yuneec is reading the file correctly (and the telemetry shows the unit being switched back to Smart mode prior to crash)?
- If Yuneec is correct (and the unit was supposedly 'switched' back to Smart mode), could there be some other explanation?? Could the switch somehow be faulty?? Even though I switched to RTH (which seems not to be in dispute), could the switch somehow still 'think' it was in Smart mode?? Maybe grasping at straws here, but I would swear on my grave I did not switch back to Smart mode.
- And just an observation ... even if the bird is supposed to do everything it can to get out of the safe circle, shouldn't it stop once it gets 'outside'?? It flew 60 yards before it crashed. I get the concept of the safe circle but does it really need to fly that far away to keep the operator safe?? How far away does it have to go before it considers itself out of the safe circle??
Now for the repair quote. I purchased the unit for $1100 (CAN) including taxes. Granted it was on sale and I think I got a pretty good deal.
The damage was: 3 broken arms, one broken landing strut, a broken camera mount and 5 broken propellers.
Staples originally quoted me $600 (CAN) for the repairs (not including the props). This included $120 for one hour of labor (reduced down from two hours - Paul the repair technician seems to be the only one sympathetic to my plight and was willing to try and work with me).
After speaking with the Yuneec supervisor and telling her the quote seemed somewhat excessive (seeing as I could spend another $500 and get a brand new unit complete with an extra battery and receiver), they reduced the quote down to $500.
This still seems high to me though?? I think Staples is planning to replace all three entire arms (including the motors). I wouldn't have thought the motors needed to be replaced though?? I can't say for sure the motors weren't damaged, but I don't think Staples has even bothered to test them. Paul indicated their standard procedure is to simply replace the entire broken arm for that type of repair.
Unfortunately I don't have any photos of the damage, but I believe it was only the plastic arms that broke ... specifically where the arms mount to the frame. There was no apparent damage to the frame itself. Just where the arms connected.
- Does a $500 repair bill for that type of damage seem reasonable?? Even if it includes 3 brand new motors. Are the motors that expensive? I find it hard to believe that 3 plastic arms, a plastic camera mount and one landing gear should cost that much to replace.
Seriously considering just having the entire unit sent back to me untouched. I'll either go buy another one (and have tons of spare parts for it) or sell off the broken one for parts and recover what I can from the original investment.
My sincere apologies for the book here people ... but very much appreciate any feedback : )
Thanks Jeff : )Jethros,
Don't forget about the last option you posted, that being another hull.
The Bind and Fly kits, in my opinion, are definitely worth it. Get the H, the camera, props, and battery. The battery, by the way, works out to $50 (U.S.) so definitely worth it.
Several positives of this approach:
1) You get flying again sooner than later.
2) You can take your time repairing your original H, even if you have someone else do it for you.
3) When you do have your original back to flight worthiness, you have a backup.
You may find, once you have more flight experience, the need to fly is far greater than the cost of ensuring you have ships to fly!
One closing comment, meant for all who jump in with the H as their first entry into drone ownership and flight: Take your time and learn on something more forgiving to the bank account before taking your prize out to the backyard, even to "just see it hovering".
Check out the many $40-$80 (U.S.) options available, along with prop guards, with which one can learn, have fun, and be prepared, all in the comfort of your favorite lounger. Just don't fly around any breakable treasures of your significant other, if applicable.
The stress level of those first H flights will be much reduced, and the likelihood of successful flights increases greatly.
Good luck with your adventure!
Thanks Jeff : )
One of the first things I did after crashing my H was go out and buy one of the cheap 'toy' drones on the market. Figured it would be a good option to learn and practice flying in angle mode whilst waiting for my H to be repaired. Looking forward to seeing how my experience/new skills transfers over to flying the H.
Question for you though. Can I get you to clarify what you mean by 'Bind and Fly kit'?? Is that basically the entire package minus the ST16 receiver?? So double everything but only one receiver?? Is that kit just something available directly through Yuneec?? Suspect I might be able to find that somewhere on their website??
Jethros
You posted the telemetry log from your flight and asked if anyone could check it. Although I am also quite new to the H, I have found some knowledgeable people out there. One of them is Helmut Elsner who developed Q500log2kml and whose manual gives much info about the log files. Using that info, the log seems to show that you took off at 20:02:22 but the mode is "Smart mode - follow me". At 20:03:21 this changes to "Return to Home" with a landing started at 20:03:27 but at 20:03:31 it changes again to "Smart mode - follow me" and four seconds later status is "Emergency/Killed".
I hope this makes sense to you and good luck with the rebuild - hope you are flying again soon.
"Emergency-Killed"... you pushed the red button in flight?
