Typhoon H Pro Batteries
UK
Hi, I'm Based in the UK and after a couple of Typhoon H pro batteries. Anyone know where I can get these in the Uk rather than China ?
I'm being told the current Typhoon H batteries are not compactible for the Pro.
Many Thanks
By Typhoon H Pro, are you referring to the original H480 series with the RealSense?D8209076-A742-40DA-9AA7-643CE13990DF.jpeg
Lithium Polymer (LiPo) for H480 series
High Voltage Lithium Polymer (LiHV) used with the H Plus and H520.
Note the difference in the contacts in the center that are used for balance charging.
Actually the H 'Pro' and the standard H are the same and use the batteries as shown in DoomMeister's first example. When your being told that the 'current' Typhoon batteries will not work, it may be that someone is referring to the H3.
But without a doubt you can buy and use standard Typhoon H batteries in your machine.
Many Thanks
They take the same batteries I have a typhoon h and a typhoon h pro and I use the same batteries in both
The batteries for the Typhoon H/HPro (H480) are all the same and the connector looks like this. BE863288-E673-4AAD-A797-AE3BEE7877F3.jpeg
The batteries for the H520/H Plus will work in the aircraft, but the balancing contacts are different and take a different charger. The contact area looks like this.
Note that the H480 batteries have round balancing contacts and the cells are LiPo with a 4S nominal voltage of 14.8V.
The H520/H+ batteries have flat mini Deans balancing contacts and are LiHV with a 4S nominal voltage of 15.2V.
NetsolWater
