Typhoon H UAV SIM Instructions
Hi
The UAV Sim has now been upgraded to include the Typhoon H. It took me over 3 hours to get it working due to not being able to bind the sim with the ST16. I did look on the net and You Tube but could not find anything to help. I eventually went through every combination of key i/p’s and finally cracked it. To save others going through the same pain I did, I thought I would post some instructions
This works with UAV SIM V2.10 Dated 18 Oct 16 available on the UK Yuneec website
Enjoy
Setting up a SIM model on the ST16
If you have not already done it, set up a new model on the ST16
ST16 - Model Select -> OK
ST16 - New Model -> Create new model
Type in a name e.g. SIM àSelect model type “Typhoon H” - >Save
PC - Insert SIM UAV dongle
PC Start the UAV SIM
PC - Model -> Select->Typhoon H -> OK
PC – Radio-> Bind Yuneeec USB Receiver
PC Displays “Please set the Transmitter into bind mode then click OK”
DO NOT Click OK YET
ST16 - System Settings ->OK
You now need to find the receiver for the dongle
Go back to your PC
PC should still be displaying
PC - Now you can Click OK
PC should now be displaying
”In the bind menu of the transmitter now select the USB receiver SRXXXX then click OK”
DO NOT Click OK
ST16 - Press Refresh
The dongle receiver name should now appear in the aircraft model window
e.g SR23s_12000.05
Follow the these instructions EXACTLEY
ST 16 - Press the receiver name
ST16 -Press Bind, ST16 now displays “Connection established”
ST 16 - Press OK
PC Should be still be displaying ”In the bind menu of the transmitter now select the USB receiver SRXXXX then click OK
PC - Now you can select OK
PC Should now be displaying “In order to establish the connection, return to the transmitter main screen by pressing the transmitters back button twice”
DO NOT PRESS OK ON THE PC YET
ST16 - Select the back button
PC Should be still be displaying “In order to establish the connection, return to the transmitter main screen by pressing the transmitters back button twice”
PC - Now you can Press OK
You should now see
PC “The bind procedure has been completed successfully”
PC - Select OK
Tip 1 The Typhoon H will not take off unless the hare / tortoise switch is set to hare
Tip 2 If you get errors with binding, forget messing with the programme on your PC, it does not help, turn off / on the ST 16 and start again.
Reactions: NWSaint
Hi, where do you get the dongle? Was my H supposed to come with one?
Thanks. I wish I had known this five weeks ago. Instead of a sim I've been crashing a whole other drone!
The TH does not come with a dongle, you have to buy it separately
My Typhoon H came with the USB Simulator Stick in the box I purchased at Costco.
Thank you so much for the instructions on Binding to the simulator. Without them I would have needed to recruit a neighborhood ten year old to help me. Too complicated for this OF to figure out.
I bought the Costco package. It came with a simulator.
Something easily missed: The ST 16 Turtle / Rabbit rotary slider must be on Rabbit. The Simulator will not work if the ST 16 is in "Turtle".
I found that "Turtle" mode will work if you engage it after you take off in "Rabbit" mode. Set the control to "Rabbit", take off, and then put it back in "Turlte" mode and it will work.
I also got the Costco package. I believe you get a couple extra spare rotors also, there were 4 in the box and then 2 more in a plastic bag.
Hi
The UAV Sim has now been upgraded to include the Typhoon H. It took me over 3 hours to get it working due to not being able to bind the sim with the ST16. I did look on the net and You Tube but could not find anything to help. I eventually went through every combination of key i/p’s and finally cracked it. To save others going through the same pain I did, I thought I would post some instructions...
Thanks for posting this. I played with the thing for an hour trying to get it to work then came across your instructions. Worked perfectly. Many thanks for the time saved, I was ready to give up and trash a few more props.
Just to note, when I first got mine, I tried the "broken line curve" setting in my ST-16 and the Simulator did not like it at all. Never tried to actually fly the H with BLC set up.
Thanks for the great post. Spent an hour playing with the Sim last night. Was working, and started testing out turning off GPS mode. Much harder to maintain static location! ;) So in that testing, must have moved to turtle mode, as I couldn't take off anymore. Tried rebooting PC and ST16, and more - finally called it a night. Something so simple! Would be nice to have a simulation for the camera too! Can the Wizard be linked to the Simulator?
Got the basic H from Costco as well, and it had issues with not wanting to land. Sitting on the ground, altimeter was fluctuating from -2 to 15'. Returned that one and ordered the H Pro with Realsense. Got it Tuesday - love the realsense so far, but haven't done much yet.
Thanks for the info!
Steve
Steve
Yes, that would be nice; very nice. I suspect it would also be very expensive to develop.
No idea. Nothing in instructions that I have found.
> love the realsense
RealSense is a great concept, however I can't seem to bring myself to actually trust it. I'll eventually try it, but it will not be today. Meanwhile, I'm having a lot of fun with the camera; shot some straight down pictures of a piece of real estate I have for sale & overlaid a survey document on it. Made a great sales tool.
Yep, but sure would be nice. :)
It looks like you set it up the same as the TH.
Will have to try that tonight - will be nice to try it there first. Wish there was better documentation for all this stuff.
> love the realsense
Played with it for a few minutes, but will have to see how it works in real situations. I look at it like an added protection to help protect the TH from myself. ;)
Hi
Enjoy
DO NOT Click OK YET
Go back to your PC
DO NOT Click OK
e.g SR23s_12000.05
ST 16 - Press OK
You should now see
PC - Select OK
Worked for me Thanks
Reactions: NDJollyMon
Mine won't take off, any ideas why, I have it in Hare Mode, but it works fine in the challenges mode all of them, takes off fine there..
gbare
