Typhoon H vs. Typhoon H Pro
Salinas, CA
I thought that the only drone difference was that the Pro came with the Real Sense module added. I now see that in the Pro the RealSense is part of a single unit that contains the IPS, fan and main LED. Is there any documentation available that discusses these and any other differences between the models? All of the videos I've seen only show the standard version.
In UK the Pro is available with or without Realsense, the standard is called advanced, in US it's a bit different. Pro here comes with wizard, backpack, extra props and bag. Realsense can be added or taken away, you'll still have the standard obstacle avoidance if you remove it. I think the rear bit you refer to is the downward facing sensors, you just unscrew existing light, and replace with the module.
Frida Gold
