Typhoon went for a swim. Advice Please
Is this your drone?
I experienced a similar accident.
If drying has no effect, which I doubt since you saw smoke, I suspect a mainboard replacement is the best option.
You can do it yourself like I did. Will save you a lot of cash and shipping fees.
Heres my tutorial on how to do it.
Good work on the video. I also like your setup for testing the motors.
Reactions: Crazy Crow
Sort of interesting that had he been registered, which I doubt he was, he might have been tracked down that way as well. Brings up a good point, I wonder what percentage of people are actually registered with the FAA? Personally I'd be surprised if it was more than 25% of hobby operators.
So is going to use the toothpaste he found to brush his teeth after dinner?o_O:eek::rolleyes:
SO????? Any updates on this? Did you get your drone back up in the air?
My Typhoon H decided to bounce up with a mind of it's own after landing; flip; and walk it's way into a fresh water lake. I pulled it from the water fully submerged in less than 3 seconds; electrons are faster than 3 seconds; I know... Smoke was coming from the battery compartment; most likely some of ESCs on the mother broad. I have contacted Vertigo (they have been AWESOME every time I have gone to them) they suggested replacing the motherboard. They mentioned that they flight controller broad might be bad too; but is not something available on the market.
So here is the dilemma; questions; debate...
I cannot confirm if the camera is OK or any other electric parts of the drone. Now that it is completely dry can I try to power it up and see what works and what doesn't without fear of frying more components?
If anything other than the mother board needs to be replaced; i.e. the camera; flight controller; the cost of the repair starts to out be more than a new base unit.
Thoughts? Ideas? Suggestions?
Oh, maybe you can bring it to maintenance worker, he can repair it.
catfish
