updating firmware....
anyone point me in a direction for up to date firmware, havent been flying for about a year so im well out of date I think but the scene is very confusing now as all the help vids are out of date, UK btw.
The link below leads to the Yuneec USA firmware website. But I notice it has a release date of 2017. If you were up to date a year ago, you're still up to date. Also note Firmware updates are a common source of problems reported on the forum. If you don't have any performance or safety issues to address, I hope you will consider leaving your current firmware as is. Even if it is not the most current.
"https://www.yuneec.com/en_US/support/downloads/typhoon-h-en-US.html"
Reactions: Mrgs1
Henly,
There have been no new firmware releases since Feb 2017 for the H so you should be good if it was flying ok then it should again. Don't forget to clean the sticks and let it sit for 10 or 15 minutes with the H turned on but motors not going out in the open to get the GPS almanac reloaded and the small battery recharged in case it went a little flat whilst not being used.
However, if it acquires satellites really good in the first 4 to 5 minutes I would say that you are all good. Check the sticks in the hardware monitor section that they are giving full readings, otherwise you may need to clean them. Johnno Hennessy ( Australia)
Reactions: DoomMeister
Ludwig
