so now I've assessed the damage, I need a new upper and lower body shell.. some more props. (have enough to fly again when its repaired, need some spares) the camera mount that is on the camera, and one B arm. then I should be good to go again. bleah wish the motor arm was cheaper, the rest is fairly cheap. the arm, not so much.. motor seems fine, and the led is also fine.
