The case popped open on impact with no observed damage except the large round glass on the bottom and It is cracked. Is this something I can fix myself? thanks in advance for any and all suggestions.
@Pman should be able to give you pretty good instructions on doing just that.
Is there any chance you are from the Upper Peninsula of Michigan? Drone pilots there think there are bird feet mounted on them instead of landing gear.
I've dropped my breeze several times and the case has come undone to differing degrees with no actual damage and they just pop back together. Too bad about the bottom glass, never broke that.
