Which camera on the H520 ?
Hi which camera are you using on the H520 ?
I own a Typhoon H and a Typhoon H plus already and i'm thinking of buying the H520. But for example can i fit the C23 camera of my H plus on the H520. The C23 is normally the same as a E90.
Marnix
Hi Marnix,
You are right, the e90 for the H520 and the c23 are nearly identical - there is only one small but crucial difference. The two Cameras use Different protocols to communicate with the drone.
So you are not able to use the c23 with the H520, or the e90 with the H+.
Greetings Marc
Right. The H520 can utilize the E90, E50 and several types of thermal cameras. The E90 is better for video than the E50.
xbytesolution
