Did you follow the Youtube videos on binding the H?Hi guys,
I need to bind camera of my TH . I have already installed firmware v.25 and v.28 in my Typhoon H but can't bind its camera and if I use GUI won't recognize its firmware. Does any know how do I fix these problems?
If you have a phone or notepad that will receive 5.8GHz wifi, then see if it shows up on the available wifi list while it's still mounted on the H with the power on.Yes, I did it. This is not my first Typhoon H which I configure it. I believe there is cut wire or damage board in my gimbal. All the procedures to bind it we have done.
Yes, it's possible the wifi on the camera or the ST16 is not working. That is why I suggest trying to connect to the camera using a phone or tablet that can use 5GHz wifi. That will help determine which unit is faulty. Is this a new unit under warranty?Hi Steve Carr,
I am trying to connect its wifi but always select and obtain a network then exit to initial screen on ST16 no wifi is been connected. Is it possible my ST16 has a wifi damage? Or wifi damage is in aircraft's module?
I've connected with my phone wi-fi in ST16's Ipad mode normally then I exit to home mode and appear its Wi-fi 5GHz icon and desappear immediately. I believe that camera transmitter wi-fi is damaged. Am I right? If I'm correct do you know which part I have to change?First you need to find out if the camera is transmitting a signal. You need a phone or notepad that can use the 5GHz band. Then install a wifi analyzer app. Turn on just the H with the camera installed. Open the app and look for the camera wifi. The picture below shows several CGO cameras on the phone.
