- Joined
- Oct 29, 2016
- Messages
- 27
- Reaction score
- 3
- Age
- 71
Interesting. What kind of shell? Do you have a link?Lots of good info there. I shoot a lot over water. I chose to enclose all of the electronics in a waterproof shell. Having the electronics survive is only half the battle. If you crash in water, you need to recover the model which is much easier if it floats.
I have used the Dex shells made in Croatia. There are others available elsewhere.Interesting. What kind of shell? Do you have a link?
So, if I understand correctly, the bird is disassembled, and all the components are then reassembled within the shell? Wish they had one for the H.I have used the Dex shells made in Croatia. There are others available elsewhere.
DeXModels | Professional Multirotors
The difficulty would be the camera and gimbal. I have seen a few hexcopter shells that were waterproof. The Dex Nuke is beautiful but only takes 8" props. The HexH20 is also available. Both are expensive.So, if I understand correctly, the bird is disassembled, and all the components are then reassembled within the shell? Wish they had one for the H.
