Yuneec Mantis Q Power Led Wouldn't Go Off
Dear Forum, i recently purchase Yuneec Mantis Q Power Led Wouldn't Go Off after turning the drone off, when ever i insert battery the green lights turns on without pressing the power button on the drone...
but the drone is working perfectly ... but when i turn off the drone after using it, the greens light is always off.
i have reset the drone through the small holes around the SD card, but the light still on after resting the drone through the holds
that can i do next?
How to fix the sensitive Controller
Secondly have been using Q500 4K in the past, the remote was smooth , i noticed the Mantis Q controller is very sensitive, is there away to edit the controller to working smoothly and slowly?
Sounds like a broken power button ! If you bought it new then Yuneec should replace that for you if you do a warranty return.
Nothing is broken the Drone responded to the power button and fly normally, the only issues if I dont remove the battery from the Drone the led light keeps turn on...
Normally I can turn off and on the Drone fly it.
The only issues is the led is always on without turning the Drone on
Smyers
