Yuneec Typhoon h multi battery charger
Waldoboro Maine
Just purchased from Vertigo drones
I hope this works good for Dee-cycling the battery for storage I don't fly all my drones much
Has anyone use one of these and how well dose it work hope I didn't waste money being on fixed income
KG-TZSZ-1A Venom 400W 4 Port Charger for the Yuneec Typhoon H Battery
Venom 6700mAh Typhoon H Battery: No Venom 6700mAH Typhoon H Battery
In Stock
$229.00 x 1
I've had mine for two months now and it works just fine. I can now recharge my batteries in 50 minutes to an hour. Recycling takes a bit of time.
I like it because it charging 4 at a time. Putting into storage mode also takes time, but I have never measured the voltage once that cycle is complete.
I have two of these, the first one failed on second usage (two bays + USB), Venom sent a replacement which works perfectly.
I'm on my third since last March as the first two failed and were replaced by Venom. Now, a port on the third charger has started to act up. I like the functionality of the unit, but haven't had good luck with reliability.
Axel66
