would be smart to start thinking about testing cell resistance,I do use 0ne like that now. Keith C.Do the batteries slide in and out of the aircraft without binding?
Is the puffy area in the plastic label area and compresses in with gentle finger pressure?
If your answers are both yes your batteries are normal.
This one is a new one on me. How do I check and what should the resistance be?would be smart to start thinking about testing cell resistance,I do use 0ne like that now. Keith C.
several videos on you tube explain this as well as some of the more knowledgeable members on here,but you should look it up anyways. I use a tenergy tester,. Each cell has it's own reading in milliohms,or mah. Low readings are good ,while high readings ,say over 20,and caution indicated. New batteries can be 2,4, more less up to 10 mmah.Different readings will be had every time you check. but the extremes mean caution. Keith C.This one is a new one on me. How do I check and what should the resistance be?
Which tenergy tester would you recomend?several videos on you tube explain this as well as some of the more knowledgeable members on here,but you should look it up anyways. I use a tenergy tester,. Each cell has it's own reading in milliohms,or mah. Low readings are good ,while high readings ,say over 20,and caution indicated. New batteries can be 2,4, more less up to 10 mmah.Different readings will be had every time you check. but the extremes mean caution. Keith C.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
