I can the password window pop up if that's what you mean. Still PW Protected!Can you see the calibration menu?
sandisk U3 A2 works in new build.Only an application update?
I wonder if this has to do with the SD card format function.
Will check after work today for the update if it is available for my system (running 822).
It is not a patch, they just updated the app.sandisk U3 A2 works in new build.
About time Yuneec starting to use PACTCHERS instead of full build
Your code automatically gets carried on, you don’t have to put it all the time.I wasn't having any problems with 822 at all, and had my NFZ code loaded in that build. I just downloaded this one and put my code in afterwards, I got a big red triangle with an exclamation point inside it. I'm assuming it means it didn't need it again?
Sending you a PMMine still shows on the screen after the update.
I got discharged from the Navy there!
