C23 connection issues
Hello all, I have a problem I'm hoping someone can help me with. I have a typhoon H Plus with C23 camera. Only about 2 hrs of total flight time on bird with no problems until now. When I turn on the bird, everything boots up like normal. connection gets established with the bird, then the camera. after about 20 seconds (bird is still grounded) the camera feed drops out. I went to the connections menu on the transmitter and it shows connected to the bird but searching for signal under the camera. I turned everything off/removed the battery and rebooted. had the exact same thing happen again. I repeated this cycle 4 times with the same result. All firmware is up to date. please help
gocdunn
