Can i use a second groundstation for Typhoon H ?
Hey people,
I wanna upgrade my Typhoon H with a second groundstation. My question is is this possible ? 1 for the pilot and 1 for full gimbal control
My second question is.
I want to install a small fpv camera on the front so I have a separate camera just for the pilot. Do u Guys have tips? Thnx !!
I have zero experience to install an FPV system. There may be some "How-To" videos on YouTube.
Hey people,
For fpv u can use a yuneec skyview, the field of view is small compared to newer headsets. If u use a meta quest it’s very simple to set up fpv with a cheap capture card and the results are pretty impressive, check out Quest 3 fpv
. One thing to keep in mind is u can use the hdmi out from the st16 to headset , you could also set up a wireless fpv set up but you will increase lag( the time it takes video feed from camera to headset) . I’d go the hdmi route as little lag is important for flying. Ive seen 2 cameras fitted to the hex series , one was for video and one for thermal . It used an st16s with an external monitor to display the second video feed. It could be pretty complicated. I’ll add the video when I can locate it
skonsk
