Car charger
Is there a car charger that works for the Yuneec Breeze?
You can use a 12V to 110V Power Inverter, and plug your normal charger into that. Your local auto supply store will likely have one, if not they are available online.
Just remember not to kill your car battery by leaving it plugged in too long.
WTFDp has great advice. Grab an inexpensive inverter. If I can make out the microscopic type on the breeze charger, it wants 0.8 amps and lets assume 120v (I used to be able to see that small). That should put you at a 100w inverter. Maybe a bit more headroom, say 120watts. These are cheap if you're in the states: any car parts shop (Advanced Auto, Walmart), even Harbor Freight will have these for like 25 bucks. They usually include a USB charging port - a nice thing to leave in your car anyway.
Reactions: DoomMeister
Djsc
