CGO CAMERA ISSUES
Hi, My CGO camera won't connect with my controller. The drone and controller are connected. I dod update the firmware on all systems.
Not sure what to do now? HELP!!
Thanks
Try rebinding the camera to the box.
Try removing the SD card from the box and reinstalling it in it's seat. (Many times that's all it takes.)
Do you have any lights showing on the camera ??
Does the camera react at start up ? (Pivot up and down ?)
You gotta help us help you brother....
We can guess your getting the "Not Connected" message.
What happened when you tried the things I suggested above ?
How about answer's to the questions I had ?
What have you done to try and fix the problem ?
Feed us some info.
HI, sorry to not be so helpful. I have updated the firmware. The light on the cam is just the red LED. The cam does pivot up when the drone is turned on.
I have tried to rebind the the Cam. The ST10 controller just says the Camera is not connected.
Im confused
Ludwig
