- Joined
- Mar 23, 2016
- Messages
- 2,386
- Reaction score
- 2,138
- Location
- Bavaria / Germany
- Website
- h-elsner.mooo.com
I had the chance to play with an CGO-ET from H520. I was surprised that it can be used with ST16 and the app from H480. That means the camera settings will be controlled by CGI commands like CGO3+. The only difference between CGO-ET from H480 vs. H520 is the gimbal FW. For me the HW looks similar. I see no reason why the a FW change of the gimbal only cannot make a CGO-ET fit for H480 or H520, because the camera FW seems to be the same.
Question: Has someone tried this with success? Or is there a risk to brick that thing?
However, for the H520 CGO-ET like for H480 is it also possible to select more Lepton palettes as usual. Here is a HTML page that can do this. You have now 11 palettes.
Simply connect your device (any device that have a internet browser and 5GHz WiFi) with the CGO-ET and open index.htm with your browser. Tap on the palette you want to get. That's it.
After power off the camera will always start with the palette that is selected on ST16, not one of the additional.
