CGO3 Camera stuck revolving
My typhoon H drone has a CGO3 Camera, I was testing it out , and testing pan mode , and the camera started to rotate , and I placed pan knob straight up , and camera wouldn't stop rotating. Anyone ever have this happen .
And is it still doing that after cycling the power on and off on the H? I had that occur some time back and if I remember I had to had to go into the settings, create a new model and completely re-bind. After you successfully re-bind, do a gimbal calibration.
Stopped after turning st16 and typhoon h off ,and restarting
Many moons ago after doing a firmware update my TH camera started doing that on my post update test flight. And yes, a power cycle solved the issue. Not had this problem since.
Reactions: Robert007
Reddybook
