CGO3 hook up on Typhoon H
Does anyone know how to connect CGO3 to the CGO3+ mount? The CGO3 only has three contacts - Not getting power to the camera now.
It should work without any changes. The contacts setup of both cameras is compatible.
If there is no power the fuse may burnt or cabeling from contact blades to gimbal board is defect.
You will not have tasks anymore for the Typhoon H without the CGO3+. Reason is that there is no more the serial connection to the camera availbale . Only +, - and PWM. No Tx/Rx used in CGO3.
Reactions: timburns78
misterfantastic
