CGO3+ Lens Replacement
Bled, Slovenia
Hi, I recently bought the PixAero 3.77mm lens and I intend to replace it with the stock lens as I scratched it and it shows in the footage. I'm just wondering if anyone knows for what should I look for and be careful about when replacing the lens?
There's some YT vids on how to do this
Be careful removing the old lens, people have ruined the sensor being over zealous, some good image results have been posted on here.
The most critical part is as stated before removing the old lens. The old lens ist screwed and glued to the circuit board. In order to losen it you will first have to unscreq it and then use aceton to soften glue. When the glue is soft try to remove as much as possible. After that the lens comes of with barely any force. During the whole process take great care on not to damage the flex wire.
Reactions: Andrazon
I removed the flex wire and got the lens part away from the gimbal, so that is no issue :)
Man that’s a bummer, I’ve been considering replacing my stock cgo3+ lens with the pixaero
wilko
