- Joined
- Mar 29, 2018
- Messages
- 1,254
- Reaction score
- 223
- Age
- 74
Does anyone know the difference between soft and hard dampers ?
Which is better to reduce the jello
Effect .
Effect .
WE WILL DO A BETTER TEST ON THEM LATER FOR THEFor what it’s worth, the replacement top plate and dampeners I just got from Vertigo Drones is the old style with the stiffer dampeners I prefer.
ONCE THE WEATHER GETS BETTER I WILLI’ve still got a set of the old 3 lobe dampers.
SINCE MY TYPHOON H IS OUT OF WARRANTY, I AM KEEPING A REAL GOOD EYE ONE EVERYTHING. LOS ONLY FOR METhe RS housing has less clearance so it’s easier for that dust cover to make contact then on a standard H. My problems all started when the mount and dampener design changed. The new design with the wider retainer washer and softer dampeners is less trustworthy. I’m searching for old stock replacements for safety back ups. If it has the sloped top rear with the two arrows, it’s the new design. The old one is flat across top mount and has single centered arrow at rear. Hang onto those if you got them. They addressed crash problems with the redesign at the expense of gimbal reliability.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
