Cgo3 wifi
Hi all, I have an older Q500. I'm having issues with the CGO3 camera not showing up in the binding process. The camera boots up like it's supposed to; it has a white light up front and the green flashing light for the Wi-Fi, but it won't show up in binding. I've tried with the ST10+ and the ST16 transmitter. Any ideas? Thanks in advance.
A quick thought is a bad antenna. The shield has a habit of breaking where the cable part joins the actual antenna. You can check that using guidance provided by @DoomMeister in "Poor wifi 5.8ghz feed from the C23" CGo3 series and e90/C23 series are pretty much the same, just the mounting is different
cubespace11
